Synology VPN
cpg_juraj
cpg_juraj Posts: 19
edited April 2021 in Security
Hi.
We have IPSec between two offices with two Zywall USG 100.
  1. zywall 192.168.50.1-245
  2. zywall 192.168.53.1-245
Our synology is in .50 network. It also runs a VPN server. When a user connects via Synology VPN it is able to talk to .50 network, but unable to reach .53 network. What rule do I need to create and where to allow the communication?
Thank you for your help.
Juraj.
  • mMontana
    mMontana Posts: 1,248
    50 Answers 1000 Comments Friend Collector Fourth Anniversary
    You should ask to Synology Forum, IMVHO. This is part of routing table of your NAS (if availble).
    Otherwise you can use L2TP VPN to allow a user to connect only to Synology AND .53 network.
  • LAURAM
    LAURAM Posts: 10
    If you have NAS in your topology, check your NAS and Zywall USG100 .50 routing table first if it has .53 routing in it.
    IF not,you can add policy route on both your NAS and Zywall USG .50 routing table to make the communication success.
  • cpg_juraj
    cpg_juraj Posts: 19
    Hello and thank you for taking the time to look into my "issue." I have been working with zywall for very short time. I already have some routing created. Is this what you mean? My goal here is to have the user that is in .53 network, connect via synology vpn from outside and then RDC to his PC.
  • lalaland
    lalaland Posts: 86
    First Answer First Comment Friend Collector Fifth Anniversary
    @cpg_juraj What is the PC's IP when it connects to synology by VPN?
  • cpg_juraj
    cpg_juraj Posts: 19
    Synology VPN is set to assign IP addresses in a range 10.0.8.10 - 10.0.8.20. I tried to add a rule to allow traffic from a created object for this specific range to .53 network. I might be missing something or not doing it correctly.
  • jasailafan
    jasailafan Posts: 181
    5 Answers First Comment Friend Collector Fifth Anniversary
    Your scenario is similar to this FAQ.
    https://businessforum.zyxel.com/discussion/2764/how-to-forward-traffic-to-branch-site-server-after-client-established-vpn-tunnel
    At the site .53 network, create a policy route.
    Incoming: any, Source: any, Destination: 10.0.8.10 - 10.0.8.20, next-hop: VPN tunnel
    At the site .50 network, create a static route.
    Destination IP: 10.0.8.0
    Subnet Mask: <the subnet mask of 10.0.8.10 - 10.0.8.20>
    Next Hop: 192.168.50.x (Synology's IP)
    Create a policy route.
    Incoming: any, Source: any, Destination: 192.168.53.0/24, next-hop: VPN tunnel
  • cpg_juraj
    cpg_juraj Posts: 19
    Awesome, that`s what I was looking for. I will apply the settings and will post back the results. Thank you.
Security Highlight
