Does GS2210-24HP support IEEE 802.3ac?
I would like to know if the Switch GS2210-24HP supports the IEEE 802.3ac protocol? In the product datasheet it says one of the Standard Compliance features is the IEEE 802.1Q VLAN tagging protocol. Since the VLAN tagging function is often associated with the IEEE 802.3ac protocol, does this means the GS2210-24HP Switch supports it? If it don't supports, the VLAN tagging can still be made by this switch? Does the header still have the 4 bytes adition, summing up 1522 bytes?
Thanks in advance.
Best regards,
Caio.
Hi @Caio
Yes, GS2210 series can support 1522 bytes max frame size to allow additional 4 bytes VLAN(Q-tag) header.
Zyxel_Lucious
5
Hi @Caio
Zyxel_Lucious
5 -
Thank you very much for answering my question.
Caio.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
