No access to switch XS3700-24
I can't access to switch with WEB-Interface and Telnet.
I access to switch with console, but many errors on it.
To access with telnet I only can reboot the switch. But I have to enter to switch without reboot to backup configuration. If I reboot the switch without backup, I can lost data.
How can I enter to switch?
Hi @liaoweihan,
I will send the file to you via private message. Please check your community message box.
Zyxel Melen0
This is with console. So many errors
Hi @Janbolat
Can you still access debug mode with console cable during booting?
If yes, please refer to attachment to retrieve your ROM file.
https://us.v-cdn.net/6029482/uploads/719/7R4YE0F7FVH7.docxAnd then re-upload the latest firmware (.bin) and ROM file (the one you just downloaded) to see if you can recover the switch, find below for your action:
If debug mode is not available, it's probably a hardware issue and you may have to RMA (unfortunately the config is irretrievable).
Zyxel_Lucious
Hi @Janbolat
By the way, in case the retrieved ROM file doesn't recover the switch, please try default ROM as well to factory-reset it.
If possible, you can also send the broken ROM file (by PM) to us, we'll try to save your config.
Zyxel_Lucious
Thanks for answering. But I can't do it right now. Yesterday I just reboot the switch.
Later I'll do it and answer you.
Could anyone please kindly provide me with the ROM and Firmware of XS3700-24?
Many thanks
Hi @liaoweihan,
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
