Does GS2210-24HP support IEEE 802.3ac?
Caio
Caio Posts: 5 image  Freshman Member
edited August 2022 in Switch
I would like to know if the Switch GS2210-24HP supports the IEEE 802.3ac protocol? In the product datasheet it says one of the Standard Compliance features is the IEEE 802.1Q VLAN tagging protocol. Since the VLAN tagging function is often associated with the IEEE 802.3ac protocol, does this means the GS2210-24HP Switch supports it? If it don't supports, the VLAN tagging can still be made by this switch? Does the header still have the 4 bytes adition, summing up 1522 bytes?
Thanks in advance.
Best regards,
Caio.
  • Caio
    Thank you very much for answering my question.
    Caio.
