Trunks, VLAN, and uplinks.
Hello. I'm coming from an HP/Cisco background but I'm running into issues getting this GS1900-10HP switch connected to my network.
For this switch I'm concerned with three VLAN.
VLAN 1 - Default VLAN, the switch has an IP on this VLAN.
VLAN 60 - VOIP VLAN.
VLAN 150 - DATA VLAN.
The switch works fine connected to my HP switch via port 1, I can ping it and log into the menu. Under VLAN Port I have it untagged on VL1, and tagged on VL 60-150. Very HP'ish.
Now on port 2 I want to have a PC and a VOIP Phone. Normally on HP I'd have it untagged on VL150 and tagged on VL60 so I set it the same. I have it connected like this, Switch>phone>PC.
The phone works. But I cannot connect to the PC.
So to sum it up VLAN are as follows.
VL1 - Untagged 1, 2-8 excluded
VL 60 - Tagged 1-8
VL 150 - Tagged 1, Untagged 2-8
Port 1 is set as a VLAN Trunk as well. Do I need to set a PVID on each port?
Hi @Aaron_W
Based on your description, you should also
1) Set PVID 150 on port 2 for ingress untagged packets from the PC.
2) Set the VoIP phone tagged-out VLAN 60.
Zyxel_Lucious
Fixed it. Had a tag wrong on int 1. Thanks for the help.
Spoke too soon. Got the PC connected on port 2. But now the phone isn't working.
The Voice VLAN is set for VLAN 60.
Its tagged on all ports on the switch. But my phone on port 2 cannot be reached now.
The Phone is connected to port 2, then the PC connects via the IP Phones PC port. So now my situation is reversed.
Port 1 is my trunk port, untagged VL1, tagged VL 60 & 150.
Port 2 is untagged VL 150, tagged VL 60.
The phone now cannot reach its SIP proxy on the same VLAN and I cannot ping it.
Here is the setting via the CLI
I reset the switch and reconfigured it. I notice that it is now keeping VL60 as its Voice VLAN. PC works, phone still isn't working. These are on port 2.
Here is the config.
GS1900# sh run
! System Description: ZyXEL GS1900-10HP Switch
! Revision: A1
! Serial Number: S172L07003012
! MAC Address Range: B8:EC:A3:26:D0:53 - B8:EC:A3:26:D0:5D
! Boot Version: V2.00 | 07/17/2015
! Firmware Version: V2.40(AAZI.2) | 06/05/2019
! System Up Time: 0 days, 0 hours, 32 mins, 57 secs
ip address 172.16.1.38 mask 255.255.255.0
ip default-gateway 172.16.1.81
ip dns 172.16.2.1
username "admin" secret encrypted 1N4D/wJ51UFHVOFLzBJQhg==
username "aaron" secret encrypted SUuSVC18V6KHNc8Unu6/oQ==
vlan 60
name "VOIP0060"
vlan 150
name "SHOP0150"
voice-vlan vlan 60
voice-vlan
voice-vlan oui-table 00:E0:BB "3COM"
voice-vlan oui-table 00:03:6B "Cisco"
voice-vlan oui-table 00:E0:75 "Veritel"
voice-vlan oui-table 00:D0:1E "Pingtel"
voice-vlan oui-table 00:01:E3 "Siemens"
voice-vlan oui-table 00:60:B9 "NEC/Philips"
voice-vlan oui-table 00:0F:E2 "H3C"
voice-vlan oui-table 00:09:6E "Avaya"
voice-vlan oui-table 00:0F:D3 "Digium"
spanning-tree mst configuration
name "B8:EC:A3:26:D0:53"
no snmp community "public"
snmp community "Nonpublic" ro
management access-list default
interface lag1
switchport hybrid allowed vlan add 60 tagged
switchport hybrid allowed vlan remove 1
interface lag2
interface lag3
interface lag4
interface lag5
interface lag6
interface lag7
interface lag8
interface 1
switchport hybrid vlan-trunking
switchport hybrid allowed vlan add 60,150 tagged
interface 2
switchport hybrid pvid 150
switchport hybrid allowed vlan add 150 untagged
voice-vlan
interface 3
voice-vlan
interface 4
voice-vlan
interface 5
voice-vlan
interface 6
voice-vlan
interface 7
voice-vlan
interface 8
voice-vlan
interface 9
voice-vlan
interface 10
voice-vlan
Hi @Aaron_W
Please try to configure IP phone's VLAN to VLAN 60 and test if the issue still exist.
Thanks for your help
Zyxel_Derrick
The IP Phone is on VL60 in its network settings. The switch can ping the phone server but the switch cannot pass traffic from the phone on tagged VL60.
- 588 USG FLEX H Series
- 477 News and Release
