Synology VPN
cpg_juraj
cpg_juraj Posts: 19 image  Freshman Member
edited April 2021 in Security
Hi.
We have IPSec between two offices with two Zywall USG 100.
  1. zywall 192.168.50.1-245
  2. zywall 192.168.53.1-245
Our synology is in .50 network. It also runs a VPN server. When a user connects via Synology VPN it is able to talk to .50 network, but unable to reach .53 network. What rule do I need to create and where to allow the communication?
Thank you for your help.
Juraj.
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    You should ask to Synology Forum, IMVHO. This is part of routing table of your NAS (if availble).
    Otherwise you can use L2TP VPN to allow a user to connect only to Synology AND .53 network.
  • LAURAM
    LAURAM Posts: 13 image  Freshman Member
    First Comment First Answer Friend Collector Sixth Anniversary
    If you have NAS in your topology, check your NAS and Zywall USG100 .50 routing table first if it has .53 routing in it.
    IF not,you can add policy route on both your NAS and Zywall USG .50 routing table to make the communication success.
  • cpg_juraj
    Hello and thank you for taking the time to look into my "issue." I have been working with zywall for very short time. I already have some routing created. Is this what you mean? My goal here is to have the user that is in .53 network, connect via synology vpn from outside and then RDC to his PC.
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    @cpg_juraj What is the PC's IP when it connects to synology by VPN?
  • cpg_juraj
    Synology VPN is set to assign IP addresses in a range 10.0.8.10 - 10.0.8.20. I tried to add a rule to allow traffic from a created object for this specific range to .53 network. I might be missing something or not doing it correctly.
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    Your scenario is similar to this FAQ.
    https://businessforum.zyxel.com/discussion/2764/how-to-forward-traffic-to-branch-site-server-after-client-established-vpn-tunnel
    At the site .53 network, create a policy route.
    Incoming: any, Source: any, Destination: 10.0.8.10 - 10.0.8.20, next-hop: VPN tunnel
    At the site .50 network, create a static route.
    Destination IP: 10.0.8.0
    Subnet Mask: <the subnet mask of 10.0.8.10 - 10.0.8.20>
    Next Hop: 192.168.50.x (Synology's IP)
    Create a policy route.
    Incoming: any, Source: any, Destination: 192.168.53.0/24, next-hop: VPN tunnel
  • cpg_juraj
    Awesome, that`s what I was looking for. I will apply the settings and will post back the results. Thank you.
