Http navigate failed, only https navigation is OK
totalcloud
I have an problém with my http navigation, my computer not receive the ACK and after more retransmission the web page is not accessible
I have not this problém with a https navigation.
Where is on the firewall for accept or block the http connection.
Hi @totalcloud,
Is the issue with a particular HTTP site or all HTTP websites?
If the computer is able to access HTTP website when the computer is connected to ISP directly, check the security polocy rule LAN1_outgoing and LAN2_outgoing when the computer is connected to LAN1/LAN2 of ZyWALL.
Service: any
Action: allow
You can also disable "Enable Policy Control" temporarily to clarify if HTTP is blocked by ZyWALL or not.
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
