Does Switch models XGS4600-32F and GS2210-24HP support IGMP query solicitation?
Thank you for the information and attention.
Best regards,
Caio.
Lucious,
If you allow me, I have one more question regarding this matter. Does these Switches have any feature that can replace the IGMP query solicitation?
Thanks in advance.
Caio.
Hi @Caio
We do have a workaround for you, please refer to the example of ring topology as below
- Enable STP and IGMP snooping on every switch, and make sure that switch 1 as the root bridge and IGMP Querier.
- Set Unknown Multicast Frame as "Drop" on every switch.
- Change the IGMP Quierier Mode to "Fixed" for every port between switches.
The fixed mode can ensure the demanding stream won't be interrupted in case of a topology change.
Zyxel_Lucious
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
