Does Switch models XGS4600-32F and GS2210-24HP support IGMP query solicitation?
Caio
Caio Posts: 5 image  Freshman Member
edited August 2022 in Switch
I would like to know if the Switches XGS4600-32F and GS2210-24HP support the IGMP query solicitation feature?
Thanks in advance.
Best Regards, Caio.
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    Hi @Caio
    Currently they don't support IGMP query solicitation.
    We just put the feature to "Ideas" and will have internal evaluation for the enhancement.
    Your opinion is appreciated.
    Zyxel_Lucious
  • Caio
    Thank you for the information and attention.
    Best regards,
    Caio.
  • Caio
    Lucious,
    If you allow me, I have one more question regarding this matter. Does these Switches have any feature that can replace the IGMP query solicitation?
    Thanks in advance.
    Caio.
  • Zyxel_Lucious
    edited November 2019
    Hi @Caio
    We do have a workaround for you, please refer to the example of ring topology as below
    • Enable STP and IGMP snooping on every switch, and make sure that switch 1 as the root bridge and IGMP Querier.
    • Set Unknown Multicast Frame as "Drop" on every switch.
    • Change the IGMP Quierier Mode to "Fixed" for every port between switches.
    The fixed mode can ensure the demanding stream won't be interrupted in case of a topology change.
    Zyxel_Lucious
