shutdown
Hi @Franc,
You can create a shutdown.zysh and upload it to USG60.
The content of the .zysh file is:
Use the CLI command to run shutdown.zysh at specific time and date.
In this example, the schedule for shutdown is at 11:40 on 2019-11-11 with timezone GMT+8
If the console is connected, you'll find the console message after the script is executed.
Hi @Zyxel_Emily
Thanks for your further suggest.
Please could you be so kind to reply about about my last question:
I successfully logged in via SSH and I simply wrote "shutdown". The USG immediately has switched off.
I wrote:
"ssh username@host"
"password"
"shutdown"
Is this way a RIGHT way to switch off the USG as the standard way via web interface? Or rather, does the USG switch off correctly without damages?
thank-you
Hi @Franc,
Yes, it is a right way to switch off the USG by entering the command "shutdown" via SSH.
5
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
