IPSec Tunnel: info about remote endpoint
mMontana
mMontana Posts: 1,468 image  Guru Member
edited April 2021 in Security
USG60 is connected via IPSec to other Firewalls: 2 old USG20, 1 USG40, 1 USG20-VPN.
With newer device AND IKEv1 tunnel i were able to read info about remote endpoint.
Now USG40 use 2 IKEv2 tunnels (one for LAN1, one for LAN2 which is on a different subnet), but info of the remote endpoint (hostname, serial number) is not readable anymore from VPN Status, just like IKEv1 tunnels to USG20.
It's just cosmetic, and it worked when there was only 1 IKEv1 tunnel between USG60 and USG40. Now not anymore.
«1
  • Zyxel_Emily
    Hi @mMontana,
    Build two IKEv2 tunnels between USG40 and USG60.
    The serial number and system name are shown on the VPN monitor.
    Build one IKEv1 tunnel between USG40 and USG60.
    Could you share the screen shot of the problem with us?
  • mMontana
    Here you are
    Into blue square two tunnels to USG40, with IKEv2 gateway. Into green square, the tunnel to USG20-VPN. Other Ones are USG20 tunnels.
  • alexey
    alexey Posts: 193 image  Master Member
    First Comment Friend Collector Eighth Anniversary
    Hi. Same issue.
    After long time info about remote point are missing.
    This from 1 site connected by 2 vti in 1 trunk.
    USG20W-vpn & USG1100.
  • Zyxel_Emily
    Hi @mMontana, @alexey,
    Thanks for reporting.
    It is confirmed as an issue after rekey.
    We are working on fixing it and the fix will be merged to the next firmware.
    I will send the firmware to you for verification after the issue is fixed.
  • mMontana
    On which side shoud be applied?
    Both?
  • Zyxel_Emily
    Hi @mMontana,
    Yes, the date firmware should be applied to both sides.
  • Zyxel_Emily
    Hi @mMontana @alexey,
    The firmware is sent to you in private message.
  • mMontana
    I'll try to update and test during late december. This is just cosmetic issue currently.
  • alexey
    On test V4.35(AAPK.0)ITS-WK46-r90773 all was good. After update to
    V4.35(AAPK.3) info about remote peer start missing again.
  • warwickt
    warwickt Posts: 111 image  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    Hi Zyxel_Emily alexey and mMontana FWIW, on our USG routers at V4.35 (xxx) we can confirm using cli show sa monitor command...
    • IKEv2 IPSEC Client-to-Site and IPSEC IKEv1 L2TP clients- DO NOT SHOW Serial numbers and HOST names of USG appliances.
    • However out Site-Site VTI DO show serial numbers and USG HOST names
    Using the show sa monitor command - works great
    Router> show sa monitor
    HTH
    Warwick
    Hong kong
