USG60 access specific ip address
NEWSPRINT
NEWSPRINT Posts: 6 image  Freshman Member
edited April 2021 in Security
How on this device you can make access only one specific IP address through one of the WAN-ports to a specific IP address of LAN1?
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    Policy Rules.
  • NEWSPRINT
    I have two wan ports on my device. It is necessary that the internal ip address of the type 192.168.0. *** (LAN1) be accessible on a specific port only through WAN2 from the external ip address of the type 46. **. **. **
  • LAURAM
    LAURAM Posts: 13 image  Freshman Member
    First Comment First Answer Friend Collector Sixth Anniversary
    Go to object > Address > Add address for lan1 192.168.0.X and external ip 46.X.X.X
    Go to Security Policy > Policy Control > Add Policy
    only allow the the external ip 46.X.X.X to lan 1 192.168.0.X
  • NEWSPRINT
    This method does not work correctly. I did everything according to your scheme, however, access in this case gets any external IP address, despite the record "source-externalip".
    In other words, if I substitute an address in an external field, for example, 85.85.X.X then my desired address 46.X.X.X gets access too. And vice versa ?
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    Did you configure 1:1 NAT?
  • NEWSPRINT
    Yes, I tried both options - VirtualServer and 1:1 NAT, It did not give the necessary Result. Either all the IP got access, or none ?
    And I solved this problem like this:
    1. Wrote a rule nat for port forwarding (All external ip got access to LAN1)
    2. Wrote 2 rules in Policy Rules. The first rule allows access from wan to lan1 to the external ip I need. The second rule prohibits access to all external ip access from wan to lan1. In that order.
    It worked ?
    Thanks everyone!
