shutdown
2»
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,418  Zyxel Employee
    Hi @Franc,
    You can create a shutdown.zysh and upload it to USG60.
    The content of the .zysh file is:
    Use the CLI command to run shutdown.zysh at specific time and date.
    In this example, the schedule for shutdown is at 11:40 on 2019-11-11 with timezone GMT+8
    If the console is connected, you'll find the console message after the script is executed.
  • Franc
    Franc Posts: 27  Freshman Member
    Hi @Zyxel_Emily
    Thanks for your further suggest.
    Please could you be so kind to reply about about my last question:
    I successfully logged in via SSH and I simply wrote "shutdown". The USG immediately has switched off.
    I wrote:
    "ssh username@host"
    "password"
    "shutdown"
    Is this way a RIGHT way to switch off the USG as the standard way via web interface? Or rather, does the USG switch off correctly without damages?
    thank-you
