Usg40 and remote desktop
Scenario,
I have 3 pc and a server in my lan, and usg40 firewall.
All Pc are in domain on server
I done step by step this guide using 3399 for secondary port and using pc MYPC with 192.168.1.100 ip
Pc MYPC has remote desktop enabled and windows firewall disabled
But nothing, I try inside lan from another pc using 192.168.1.100:3399, but nothing.
Any help?
Thank you
if you want to connect from the internet, you have to put your public ip.
nico
hi Nico,
yes, I have !
If you have 3 pc in lan and you'd like to access RDP of 3 pc from Internet, just follow the guide to configure NAT rules with port mapping and security policy rules.
Ex: The default RDP port of 3 pc is 3389.
pc1: 192.168.1.99
pc2: 192.168.1.100
pc3: 192.168.1.101
Suppose the WAN IP of USG40 is 59.1.1.100 and configure NAT port mapping for pc2 and pc3. Pc1 still uses port 3389 without port mapping.
pc1: 3389 -> 3389
pc2: 3390 -> 3389
pc3: 3391 -> 3389
Security policy rule:
From WAN to LAN, destination: pc1, pc2 and pc3, service: 3389, allow.
To access 3 pc by RDP from Internet.
pc1: 59.1.1.100:3389
pc2: 59.1.1.100:3390
pc3: 59.1.1.100:3391
To access 3 pc by RDP inside LAN:
pc1: 192.168.1.99:3389
pc2: 192.168.1.100:3389
pc3: 192.168.1.101:3389
thank you, i'll try it.
Why expose 3389 to the internet? I would think you could create a rule to allow traffic from 3390 and 3391, and let translation take care of it, but it does not work without exposing 3389 to internet.0
A more safe way to allow 3389 is from source FQDN like remoteRDP.no-ip.org the connecting client runs DDNS the USG updates the IP for remoteRDP.no-ip.org and allows RDP.
Or you can NAT external port like 3000 to internal 3389 then the client uses IP:3000 for RDP
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 926 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 213 Service & License
- 339 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 446 Security FAQ
- 238 Switch FAQ
- 214 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 74 About Community
- 62 Security Highlight
