Usg40 and remote desktop
damianodec
damianodec Posts: 42 image  Freshman Member
edited April 2021 in Security
Scenario,
I have 3 pc and a server in my lan, and usg40 firewall.
All Pc are in domain on server
I done step by step this guide using 3399 for secondary port and using pc MYPC with 192.168.1.100 ip
Pc MYPC has remote desktop enabled and windows firewall disabled
But nothing, I try inside lan from another pc using 192.168.1.100:3399, but nothing.
Any help?
Thank you
  • nicolasj29
    nicolasj29 Posts: 1 image  Freshman Member
    if you want to connect from the internet, you have to put your public ip.
    nico
  • damianodec
    hi Nico,
    yes, I have !
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    @damianodec
    If you have 3 pc in lan and you'd like to access RDP of 3 pc from Internet, just follow the guide to configure NAT rules with port mapping and security policy rules.
    Ex: The default RDP port of 3 pc is 3389.
    pc1: 192.168.1.99
    pc2: 192.168.1.100
    pc3: 192.168.1.101
    Suppose the WAN IP of USG40 is 59.1.1.100 and configure NAT port mapping for pc2 and pc3. Pc1 still uses port 3389 without port mapping.
    pc1: 3389 -> 3389
    pc2: 3390 -> 3389
    pc3: 3391 -> 3389
    Security policy rule:
    From WAN to LAN, destination: pc1, pc2 and pc3, service: 3389, allow.
    To access 3 pc by RDP from Internet.
    pc1: 59.1.1.100:3389
    pc2: 59.1.1.100:3390
    pc3: 59.1.1.100:3391
    To access 3 pc by RDP inside LAN:
    pc1: 192.168.1.99:3389
    pc2: 192.168.1.100:3389
    pc3: 192.168.1.101:3389
  • damianodec
    thank you, i'll try it.
  • RickyC
    RickyC Posts: 14 image  Freshman Member
    Why expose 3389 to the internet?  I would think you could create a rule to allow traffic from 3390 and 3391, and let translation take care of it, but it does not work without exposing 3389 to internet.
    PeterUK Posts: 4,427 image  Guru Member
    A more safe way to allow 3389 is from source FQDN like remoteRDP.no-ip.org the connecting client  runs DDNS the USG updates the IP for remoteRDP.no-ip.org and allows RDP.
    Or you can NAT external port like 3000 to internal 3389 then the client uses IP:3000 for RDP
