ZyWALL USG 300 and TLS 1.2
Did you disabled weak cyphers?
Or TLS 1.0?
(backup before doing any test...)
Hi, mMontana.
ZyWALL USG 300:
Router> show ip http server secure status
active : yes
port : 443
certificate : zywall-usg-300
force redirect : yes
authentication client: no
anti beast attack : no
strong cipher suite : no
cipher suite : aes 3des des rc4
sslv3 support : no
For example, USG20W-VPN:
active : yes
port : 443
certificate : myrouter.zyxel-usg
ssl protocol : tls1.2 tls1.1 tls1.0
Zywall usg 300 is quite an old model. It doesn't seem to support TLS 1.2.
@jasailafan which device produced that output?
@jasailafan, @mMontana thanks. I would also like to hear the answer from Zyxel officials.
Hi @link000,
You need to upgrade ZyWALL USG 300 to the latest date firmware 3.30(AQE.7)ITS-WK48-r74988 for TLS 1.2 support.
The firmware is sent to you in private message.
Disable SSLv3 and TLS 1.0 using commands.
Router> configure terminal
Router(config)# no ip http secure-server sslv3
Router(config)# no ip http secure-server tlsv10
@Zyxel_Emily , thank you very much!
Everything works perfectly.
Thanks to everyone.
Hi, is it possible to receive that firmware too for the USG300?
Im also looking to enable tls1.2 but the firmware i'm using is
ZyXEL Communications Corp.
model : ZyWALL USG 300
firmware version: 3.30(AQE.7)
BM version : 1.13
build date : 2015-01-13 16:31:42
active : yes
port : 443
certificate : Fiber
strong cipher suite : yes
sslv3 support : no
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
