ZyWALL USG 300 and TLS 1.2
link000
link000 Posts: 39  Freshman Member
edited April 2021 in Security
Hello. I'm using ZyWALL USG 300.
Firmware Version: 3.30 (AQE.7) ITS-WK09-r59684 / 1.12 / 2015-03-17 00:17:38.
Is it possible to enable TLS 1.2 protocol support in the device?
Thanks.
«13
  • link000
    Hi, mMontana.
    ZyWALL USG 300:
    Router> show ip http server secure status
    active              : yes
    port                : 443
    certificate         : zywall-usg-300
    force redirect      : yes
    authentication client: no
    anti beast attack   : no
    strong cipher suite : no
    cipher suite        : aes 3des des rc4
    sslv3 support       : no
    For example, USG20W-VPN:
    active              : yes
    port                : 443
    certificate         : myrouter.zyxel-usg
    ssl protocol        : tls1.2 tls1.1 tls1.0
  • jasailafan
    jasailafan Posts: 193  Master Member
    Zywall usg 300 is quite an old model. It doesn't seem to support TLS 1.2.
  • mMontana
    mMontana Posts: 1,425  Guru Member
    50 Answers 1000 Comments Friend Collector Fifth Anniversary
    @jasailafan which device produced that output?
  • jasailafan
    @mMontana
    It is Zywall usg 300 in firmware 3.30(AQE.7).
    Strong cipher suite is enabled.
  • link000
    @jasailafan, @mMontana thanks. I would also like to hear the answer from Zyxel officials.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,413  Zyxel Employee
    Hi @link000,
    You need to upgrade ZyWALL USG 300 to the latest date firmware 3.30(AQE.7)ITS-WK48-r74988 for TLS 1.2 support.
    The firmware is sent to you in private message.
    Disable SSLv3 and TLS 1.0 using commands.
    Router> configure terminal
    Router(config)# no ip http secure-server sslv3
    Router(config)# no ip http secure-server tlsv10
  • link000
    @Zyxel_Emily , thank you very much!
  • link000
    Everything works perfectly.
    Thanks to everyone.
  • StouAdmin
    StouAdmin Posts: 19  Freshman Member
    @Zyxel_Emily
    Hi, is it possible to receive that firmware too for the USG300?
    Im also looking to enable tls1.2 but the firmware i'm using is
    ZyXEL Communications Corp.
    model          : ZyWALL USG 300
    firmware version: 3.30(AQE.7)
    BM version     : 1.13
    build date     : 2015-01-13 16:31:42
    active              : yes
    port                : 443
    certificate         : Fiber
    strong cipher suite : yes
    sslv3 support       : no
