GS1900-24E - V2.50(AAHK.0) - Bug in debug text for QoS Port Remark setting
WvandeHoef
WvandeHoef Posts: 22 image  Freshman Member
edited August 2022 in Switch
I noticed that there is a wrong text in the debug log when changing the QoS Port Remark settings. For the "IP Precedence Remark" the text for "DSCP Remark" is inserted in the log.
Istubled on this when enabling the remark dscp state and the log was showing it disabled it directly after enabling it. In fact it didn't, just the wrong text was shown for the "IP Precedence Remark" state.
  • Kim
    Kim Posts: 4 image  Freshman Member
    I don't get your point
    Do you mean the log should appear ip precedence is set to disabled instead of dscp?
    Could you share the steps of how you configure it?
  • WvandeHoef
    Correct,
    when changing the first option CoS Remark to enabled, the debug log will show "Remark Cos state set to enabled" and 2 times "Remark dscp state set to disabled".
    When changing this to Cos Remark disabled, DSCP remark disabled and IP Precedence Remark disabled the debug log will show "Remark Cos state set to disabled", "Remark dscp state set to enabled" and "Remark dscp state set to disabled", being very confusing and wrong.
    Debug log should say "IP Precedence Remark set to enabled/disabled" for the last radio button.
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    Hi @WvandeHoef
    We've confirmed this is indeed a display bug and will be fixed in next official firmware release.
    Thank you again for reporting.
    Zyxel_Lucious
  • Zyxel_Lucious
    edited April 2020
    Hi @WvandeHoef
    We've fixed the QoS syslog display bug in 2.60 firmware.
    For your information and kindly stay tuned for the upcoming new release.
    Zyxel_Lucious
