Slog connection
Please help
Hi @Per,
Can you share what kind of problem/issue you met on USG60W?
Yes sorry, I have a realy slow ssl/secure extender connection. I have the latest firmware but still I only get 1mb/s.
Force all client traffic to enter SSL VPN tunnel is disabled. The dhcp on the local network is 192.168.60.20-100 and the ssl dhcp is set to 192.168.60.101-200.
Hi @Per,
The subnet of SSL VPN (192.168.60.101-200) cannot conflict with any WAN/LAN/DMZ (192.168.60.20-100) subnet.
Try to set another subnet for SSL VPN DHCP pool.
About the SSL VPN throughput, it's limited to 5-10 Mbps transfer speed for SMB/FTP/HTTP between the SSL VPN client and LAN subnet.
You can use L2TP over IPsec/IPsec VPN instead of SSL VPN for better performance.
Changed to different subnet on SSL VPN but did not get better performance. Trying L2TP instead. Thanks for the information.
- 592 USG FLEX H Series
- 480 News and Release
