Slog connection
Per
Per Posts: 5 image  Freshman Member
edited April 2021 in Security
I am having the same problem with my usg60w. Is this patch avalibale for download.
  • Per
    Please help
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,461 image  Zyxel Employee
    Hi @Per,
    Can you share what kind of problem/issue you met on USG60W?
  • Per
    Yes sorry, I have a realy slow ssl/secure extender connection. I have the latest firmware but still I only get 1mb/s.
  • Per
    Force all client traffic to enter SSL VPN tunnel is disabled. The dhcp on the local network is 192.168.60.20-100 and the ssl dhcp is set to 192.168.60.101-200.
  • Zyxel_Emily
    Hi @Per,
    The subnet of SSL VPN (192.168.60.101-200) cannot conflict with any WAN/LAN/DMZ (192.168.60.20-100) subnet.
    Try to set another subnet for SSL VPN DHCP pool.
    About the SSL VPN throughput, it's limited to 5-10 Mbps transfer speed for SMB/FTP/HTTP between the SSL VPN client and LAN subnet.
    You can use L2TP over IPsec/IPsec VPN instead of SSL VPN for better performance.
  • Per
    Changed to different subnet on SSL VPN but did not get better performance. Trying L2TP instead. Thanks for the information.
