VPN300 - Nat not working at all, no matter if policy control is enabled or not.
Hi all, this router is being a headache so far, but it is what i have to use so... let's see if i can get help to make it work:
I am opening a port on NAT like this:
Ph port GE3 belongs to the WAN2 ISP connection.
I have tested to disable Policy control but just in case, here's the rule created
It does not work. I changed already the www management service to a different port (both http and https)
Also i've tried opening a different service on another port number with no luck.
If i attach the service to the ISP router directly, i can make it work with no problem NAT work on the isp routers with no issues.
I want to clarify that the server is on the DMZ. Not sure if it makes a difference.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
