VPN300 - Nat not working at all, no matter if policy control is enabled or not.
jjimenez
jjimenez Posts: 4  Freshman Member
edited April 2021 in Security
Hi all, this router is being a headache so far, but it is what i have to use so... let's see if i can get help to make it work:
I am opening a port on NAT like this:
Ph port GE3 belongs to the WAN2 ISP connection.
I have tested to disable Policy control but just in case, here's the rule created
It does not work. I changed already the www management service to a different port (both http and https)
Also i've tried opening a different service on another port number with no luck.
If i attach the service to the ISP router directly, i can make it work with no problem NAT work on the isp routers with no issues.
  • jjimenez
    I want to clarify that the server is on the DMZ. Not sure if it makes a difference.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,431  Zyxel Employee
    Hi @jjimenez,
    In the security policy rule, the source IP should be configured as “any”, not WAN2_IP.
