Zywal 310 VPN routing over different subnets?
We have the following setup on our Zywall 310:
LAN: 192.168.x.x/24
IPSec VPN site2site tunnel:
IPSec VPN tunnel local policy: 192.168.x.x/24
IPSec VPN tunnel remote policy: 10.0.x.x/24
VPN Client setup:
VPN client setup: 10.100.x.x/28
Our office has a few remote employees connecting with a client-vpn to local network (192.168.x.x/24). We would like to route these client connections for certain traffic through our existing VPN site2site tunnel for a remote service @ 10.0.x.x/24
What options do we have?
For instance we cannot add a second "local policy" (10.100.0.x/28) to the existing s2s tunnel. Should we then create a new vpn s2s tunnel with a local policy of 10.100.0.x/28?
We tryed to setup SNAT for vpn-client source addresses but it would not work.
Hoping someone could help us.
Thanks!
Hi @KMP,
You can follow the guide in this FAQ to configure policy route rules on both ZyWALLs.
FAQ:
How to forward traffic to branch site server after client established VPN tunnel
Hi Emily, thank you for answering. The other end of the tunnel is not a Zyxel device, i'm not sure what vpn-setup they have. But i the way you illustrate should be straight forward. We will have a look and report back.
Hi again, would there be no need for a change in vpn-tunnel configuration? I'm thinking of the vpn "Local policy":
We only can add one subnet, not multiple subnets like i described above. Will this work with only a policy route on both ends?
Try to create a tunnel for every subnet...
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
