upload last good config
damianodec
damianodec Posts: 42 image  Freshman Member
edited April 2021 in Security
hi,
I have reset my usg40 and nou I'd like to upload last good config (copied about one week ago and named mygoodconfig.conf).
In configuration, file in browse upload, insert mygoodconfig.conf and then upload button, then I can see my file in list above, I click on it and then click on APPLY button, a window show me "please wait" whit time and nothing... after 20 minutes there is still the same window with the same message with the time passed.
Any help?
thanks
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Which browser are you using?
    Are you using windows with Antivirus on browser enabled?
    Do the name file has some spaces?
  • damianodec
    Thank for your help.
    browser Chrome;
    no spaces in filename;
    antivirus, I’ll have to check
  • Blabababa
    Blabababa Posts: 151 image  Master Member
    What if you clear the browser cache and re-login? See if the settings are applied successfully?
  • Zyxel_Emily
    Hi @damianodec,
    Can you share mygoodconfig.conf with me in private message?
    What is the firmware version on the running partition now?
  • damianodec
    hi,
    it works, I uploded by Firefox!
    Just another question:
    I'd like open a IPSEC VPN and connect to USG by Zywall ipsec VPN Client.
    This client, in authentication form, ask me gateway address (my pubblic IP) and port 443.
    Have I to open this port in usg40 for its local ip ?
    thanks.
