USG 60 雙WAN支援 設定請教
Hi @Jerry686,
在CONFIGURATION > Network > Interface > Trunk > User Configuration新增一筆trunk.
假設wan1是ISP A, mode設定Active.
wan2是ISP B, mode設定Passive.
Trunk新增完成後, 在CONFIGURATION > Network > Interface > Trunk > Default WAN Trunk選擇新增的這筆trunk.
另外, 可以依照需求決定是否要勾選Disconnect Connections Before Falling Back.
Disconnect Connections Before Falling Back: 當trunk裡的Active interface恢復時, 切斷Passive interface的既有連線.
在CONFIGURATION > Network > Interface > Ethernet > wan1和wan2, 分別設定Connectivity Check.
勾選Enable Connectivity Check並勾選Check Default Gateway或Check These Addresses.
如果選擇Check These Addresses, 請填入一組合適且穩定的外部IP address, 例如: Google public DNS server 8.8.8.8.
太感謝了,謝謝您. 會再去測試,感恩.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
