LTE firmware for SBG3600
Hello Bob,I upgraded to version AAKO.9 and I lost the firmware on the LTE module.Could you give the current firmware version for LTE?Thank you0
Hi Garuda,
I sent a message to you.
Please check your inbox.
Thank you.
Regards,
Bob0 -
Hi Bob
I'm running Firmware V1.00(AAZE.2) and LTE version ALT3100_04_05_06_10_B8_LO. My LTE connection are running slow. when I'm running speedtest on wifi i'ts running as slow as 5mbps. when i'm running a speedtest on the phones LTE it's running 40mbps. Am I running old firmware verison or what could be wrong?
Regards
Martin L0 -
Hello, I would like to get latest LTE firmware also, last summer noticed performance was not what I expected.
Current LTE firmware: ALT3100_04_05_06_10_B8_LO
Current Device firmware: V1.00(AAKO.9)
Current WWAN Package: 1.150 -
Hi MartinL,
I will reply to the discussion thread which you created.
Regards,
Bob
Hi FireFlower,
I will send the link through message.
Please check your forum's inbox.
Regards,
Bob
I also need the firmware upgrade for AAKO.9.0 -
Hello there,
My LTE performance is Max. 34Mb and the subscription 150Mb.
Same sim on mobile Phone speed up to 98Mb
current SBG3600 Firmwares & WW WWAN Package Version
LTE firmware is ALT3100_05_00_02_00_81_MS
Device Firmware Version: V1.00(AAKO.9)
WWAN Package Version: 1.15
Q: Can I get all latest updates,
P.s I have 4 lines in 4G signal
BR Monte
Hi juhopol,
I reply you by message.
Regards,
Bob
Hi Montasir,
Thanks for providing the details of your SBG3600.
All the software packages (router, LTE module, and WWAN package) are already the latest.
The relative inferior downlink speed performance on the SBG3600 could be from its "LTE band support" and the "LTE technology support.
- The SBG3600 supports band 3/7/8/20. I am not sure which LTE bands your LTE service provider supports but it could be the case where your service provider has a wider bandwidth on the LTE band which the SBG3600 does not support.
- The SBG3600 supports LTE category 3 (maximum download 100 Mbps), which is inferior than your subscription, 150 Mbps.
The SBG3600's downlink speed can be limited by these 2 factors.
Regards,
Bob
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 922 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 989 Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 140 Service & License FAQ
- 72 About Community
- 62 Security Highlight
