need help to find the best setup configuration for a new network
due to some changes in our network configuration, i need to setup new routes and i'd like to have some hints to identify the best way to do it
this is the actual network map
and this is the new
site A and B are now connected with a fiber channel line via layer 2 switches.
LAN 1 A and LAN 1 B clients have to reach eachother and share services
site B needs to reach internet via site A wan ( 1 or 2) but has to keep it's wan1 line as backup.
Whats' the best way to setup this ?
Hi @DOK,
Create policy routes on site B.
Rule 1
From: any, To: any, Next-hop: fiberchannel interface of site B
Healthy Check
Disable policy route automatically while Interface link down
Remember to enable connectivity check on the fiberchannel interface of site B.
Rule 2
Healthy check: enable Disable policy route automatically while Interface link down.
Create policy routes on site A.
Rule 1
From: any, To: subnet of site B, Next-hop: fiberchannel interface of site A
Healthy Check
Remember to enable connectivity check on the fiberchannel interface of site A.
Rule 2
From: any, To: subnet of site B, Next-hop: vti interface
Rule 3
From: any, To: any, Next-hop: Trunk (default WAN trunk)
Hi @DOK,
In order to use healthy check on policy route on site B, you need to use VTI to establish VPN.
You can follow the FAQ to configure VTI on site A and site B.
How can I configure IPSec site-to-site VPN by using VTI on the USG ?
On both sites, remember to enable connectivity check on VTI interface.
Policy Route on site A
Rule 1
Source: LAN of site B
Next-hop: Gateway: system default wan trunk
SNAT: outgoing-interface
Rule 2
Incoming: ZyWALL
Destination: LAN of site B
SNAT: none
Rule 3
Source: any
SNAT: none
Policy Route on site B
Rule 1
Destination: any
Rule 2
Destination: any
Next-hop: wan1
In policy rule #1, enable Disable policy route automatically while Interface link down.
Result
When vti interface is down (VPN is down), the policy route rule #1 on site B is disabled automatically because vti interface is detected as down.
The traffic will go through policy route rule 2.
thank you for your explanation but i think my picture wasn't clear enough.
default route for site be should be the fibrechannel direct connection with site a, and, if that channel si offline, it should turn on wan1 and vpn.
my idea was :
SITE A :
activate LAN2 with same subnet as site B (192.168.151.0/24) and assign let's say, 192.168.151.253 to USG110 A. Disable DHCP on LAN2
allow traffic between LAN1 and LAN2
connect via direct fibre link switch LAN2 A with LAN1 B
so the two sites are connected
then i should find a way to tell SITE B that default route is USG110A 192.168.151.253
this way office B would get internet connectivity using wichever wan connection is online on SITE A.
BUT
i neet to find a way to "turn off" the wan 1 and relative vpn on SITE B, and activate them only if 192.168.151.253 is offline.
Hi @DOK,
Rule 1
Healthy Check
Rule 2
Rule 1
Healthy Check
Rule 2
Rule 3
- 441 Beta Program
- 210 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
