need help to find the best setup configuration for a new network
DOK
DOK Posts: 10  Freshman Member
edited April 2021 in Security
due to some changes in our network configuration, i need to setup new routes and i'd like to have some hints to identify the best way to do it
this is the actual network map
and this is the new
site A and B are now connected with a fiber channel line via layer 2 switches.
LAN 1 A and LAN 1 B clients have to reach eachother and share services
site B needs to reach internet via site A wan ( 1 or 2) but has to keep it's wan1 line as backup.
Whats' the best way to setup this ?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,396  Zyxel Employee
    Hi @DOK,
    Create policy routes on site B.
    Rule 1
    From: any, To: any, Next-hop: fiberchannel interface of site B
    Healthy Check
    Disable policy route automatically while Interface link down
    Remember to enable connectivity check on the fiberchannel interface of site B.
    Rule 2
    Healthy check: enable Disable policy route automatically while Interface link down.
    Create policy routes on site A.
    Rule 1
    From: any, To: subnet of site B, Next-hop: fiberchannel interface of site A
    Healthy Check
    Remember to enable connectivity check on the fiberchannel interface of site A.
    Rule 2
    From: any, To: subnet of site B, Next-hop: vti interface
    Rule 3
    From: any, To: any, Next-hop: Trunk (default WAN trunk)
    See how you've made an impact in Zyxel Community this year!
    https://bit.ly/Your2024Moments_Community
  • Zyxel_Emily
    Hi @DOK,
    In order to use healthy check on policy route on site B, you need to use VTI to establish VPN.
    You can follow the FAQ to configure VTI on site A and site B.
    How can I configure IPSec site-to-site VPN by using VTI on the USG ?
    On both sites, remember to enable connectivity check on VTI interface.
    Policy Route on site A
    Rule 1
    Source: LAN of site B
    Next-hop: Gateway: system default wan trunk
    SNAT: outgoing-interface
    Rule 2
    Incoming: ZyWALL
    Destination: LAN of site B
    SNAT: none
    Rule 3
    Source: any
    SNAT: none
    Policy Route on site B
    Rule 1
    Destination: any
    Rule 2
    Destination: any
    Next-hop: wan1
    In policy rule #1, enable Disable policy route automatically while Interface link down.
    Result
    When vti interface is down (VPN is down), the policy route rule #1 on site B is disabled automatically because vti interface is detected as down.
    The traffic will go through policy route rule 2.
  • DOK
    thank you for your explanation but i think my picture wasn't clear enough.
    default route for site be should be the fibrechannel direct connection with site a, and, if that channel si offline, it should turn on wan1 and vpn.
    my idea was :
    SITE A :
    activate LAN2 with same subnet as site B (192.168.151.0/24) and assign let's say, 192.168.151.253 to USG110 A. Disable DHCP on LAN2
    allow traffic between LAN1 and LAN2
    connect via direct fibre link switch LAN2 A with LAN1 B
    so the two sites are connected
    then i should find a way to tell SITE B that default route is USG110A 192.168.151.253
    this way office B would get internet connectivity using wichever wan connection is online on SITE A.
    BUT
    i neet to find a way to "turn off" the wan 1 and relative vpn on SITE B, and activate them only if 192.168.151.253 is offline.
  • Zyxel_Emily
    Hi @DOK,
    Rule 1
    Healthy Check
    Rule 2
    Rule 1
    Healthy Check
    Rule 2
    Rule 3
