USG 100 site-to -site vpn
NRdroque
NRdroque Posts: 8  Freshman Member
edited April 2021 in Security
hi
we have a site-to-site line installed, to connect a wharehouse.
This is the basic diagram how can i connec the main vpn router to my network .
Any ideas will be aprecciate.
  • jasailafan
    jasailafan Posts: 193  Master Member
    Would you like to replace VPN router-Main with ZyWALL USG100 PLUS and establish VPN between VPN route-remote and ZyWALL USG100 PLUS?
    Or do you just want to insert VPN router-Main to the right-hand side of topology and keep the VPN connection between VPN router-Main and VPN route-remote?
  • NRdroque
    I'd like to insert VPN main and maintain the connectio
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,442  Guru Member
    Hi @NRdroque,
    You can connect Vpn router Main to one unused lan interface (ex: lan2) of USG100-PLUS.
    Disable DHCP server on lan2 and set a static IP for Vpn route Main.
    On USG100-PLUS, add a static route rule as follows.
    Destination IP: IP address of the subnet of Vpn route remote (ex: subnet-1 IP 192.168.30.0)
    Subnet Mask: subnet mask of the subnet of Vpn router remote (ex: subnet-1 mask 255.255.255.0)
    Gateway IP: lan2 IP address of USG100-PLUS (ex: 192.168.2.1)
    On Vpn router Main, add a static route for traffic to company network (ex: lan1 subnet) of USG100-PLUS.
    Destination IP: IP address of company network (ex: lan1 IP 192.168.1.0)
    Subnet Mask: subnet mask of company network (ex: lan1 mask 255.255.255.0)
    Gateway IP: the IP address of the interface which is connected to USG100-PLUS on Vpn router Main (ex: IP-1)
  • NRdroque
    Hi have one question
    on VPn main Router
    shouldn't be the Lan2 adress?
  • Zyxel_Emily
    Hi @NRdroque,
    Thanks for your notification.
    Here is the revised configuration.
    Gateway IP: IP-1
    Gateway IP: 192.168.2.1
  • NRdroque
    hi,
    have configure the static rule.
    192.168.15.0 - the second site ip range
    255.255.255.0 - the second site subnet
    192.168.13.254 - ip from LAN2
    i cant ping any vpn router.
    it's needed to create a rule in the firewall?
  • NRdroque
    i have conected as the model but i only can acess from the remote location to LAN2 ip address.
    how can i comunicate with LAN1 network?
    And from lan1 i can acess nothing on remote location.
    thanks for all your help
