how can I control new computers connect to zywall
lechulysy
lechulysy Posts: 5  Freshman Member
edited April 2021 in Security
I use Zywall 110.
After connecting a new computer to zywall (no MAC in IP/MAC Binding table) I would like to receive a notification (e.g. via email). If it is possible? If not how can I block this computer to "see" LAN?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,396  Zyxel Employee
    edited December 2019
    Hi @lechulysy,
    When a new computer is connected and get IP from ZyWALL, since the log for DHCP is not categorized as an "Alert" log, ZyWALL won’t send an email notification when a new computer is connected.
    Do you let unknown computers to access Internet only but not to access lan resource/server?
    You can assign another interface such as lan2 for unknown computers and add a security policy rule as follows.
    From LAN2, To LAN1, Action: deny, Log alert
    See how you've made an impact in Zyxel Community this year!
    https://bit.ly/Your2024Moments_Community
  • lechulysy
    Sometimes the user connects his "home" computer in the office. I need to know that it happened and not allow him access to the LAN, WAN etc. Normaly the new computer has been assigned IP address from "deny" range (this range has set special rules on firewall) but it not works for LAN of course.
  • jasailafan
    jasailafan Posts: 193  Master Member
    I guess you need the function called 802.1x port security which is implemented on switch.
    Is it the scenario you need?
    https://businessforum.zyxel.com/discussion/1565/is-there-a-way-to-configure-802-1x-mac-based-on-a-gs1920
  • lechulysy
    your right, but I was hoping to do this on the router :)
  • lalaland
    lalaland Posts: 91  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Firewall/Router is working on layer 3~layer7. e.g. web authentication.
    As for your requirement, it need to restrict on layer 2 switch to avoid unknown device access to office network.
Security Highlight
