Network slow after firewall change
IkkI_Magna
IkkI_Magna Posts: 17 image  Freshman Member
edited April 2021 in Security
I use USG-100 for firewall b4
It was setup at 2007 and firmware is 2.02
I purchase new firewall usg-110 last week and the firmware is v4.35(aaph.0) for replacement.
All Routing and firewall policy are copied by hand.
Client say that they access internet slower than before.
They need to "Enter" twice the browser address bar.....
Is it any idea?
«13
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    If you WAN type is static IP, don't forget to set up DNS setting on configuration > system > dns.
  • IkkI_Magna
    edited December 2019
    Thx for advise,
    I have set DNS already...
    But some client will suddenly can not connect....
    Browser will show disconnect randomly.
    There are less than 50 clients only....
  • Zyxel_Emily
    Hi @IkkI_Magna,
    Can you share the startup-config.conf of USG110 with me in private message?
  • IkkI_Magna
    Hi, The last method can not solve the problem...
    Anyone help?
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @IkkI_Magna
    Can you share what else settings had you configured on your device since we had tried with your settings and everything seems to be fine.
    Or would you share the remote access to us in private message so that we can have more clear idea about the difference.
  • IkkI_Magna
    I have sent config file to Emily before.
  • Zyxel_Vic
    Hi @IkkI_Magna
    Yes this is what we had tested in our lab. Can we have remote check on your device? If you have concern about opening the remote access on the device, you can just allow the specific IP address to access it. Let us know if it's okay in private message.
    Thank you.
  • IkkI_Magna
    Dear Vic,
    Would you answer me some question ?
    Regards,
    IkkI
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @IkkI_Magna
    Regarding to your message,
    1. Can I confirm with you that do you want to block client access to device via https?(but http allow) or block client access to device via wan with any service?
    2. Go to Configuration>Network>Routing>Create the profile
    Need to create the address for destination, and create the service for your own server
    3.Can I know does the client and server on the same subnet?
  • IkkI_Magna
    1. block client access to device via https & ssh
    2. I try it before...but fail...
    3. yes, same subnet.....when I use old server, it is ok, when I use new server,sometimes will be that(not always.)
