Small change to DDNS
Hello PeterUK,
Just want to confirm your request,
do you want to add the domain name which is link to object list?
Example:
If yes, this feature will be supported on FW: 4.30.
Charlie0 -
Where its got custom IP to have a drop box of address objects including IP interface.
Why you need additional drop box of interface IP address object...
If you select interface, then will use this interface IP address directly.
But thats not the interface IP I need and if its e.g 192.168.1.1 it be the effective wrong IP for like no-ip to get.
Hello PeterUK,
The request "adding drop box of address objects on custom IP", I would like to move your request to the ideas section.
Charlie
Zyxel_Charlie said:Hello PeterUK,
CharlieYes thats what I would like so that the sending interface is not the IP I need to send in custom IP that can change on another interface that can't be the sender.
My thanks for adding this to ideas section
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
