[Alert] Network-Firewall-----AP Disconnect
Hello
we have the same problem with NXC 2500 and WAC6553D-E
for solution installed latest firmware but problem still going on
anyone can help
thank you
No. Date/Time Source Destination
Priority Category Note
Message
1 2019-11-21 14:18:30 192.168.1.73:35960
alert capwap
AP Disconnect. MAC:04:B0:64:21:D4:F2,Name:lifter,Reason:Idle in RUN State,Model:WAC6553D-E
Cloud you please describe more details about your symptom? such as how long the AP stays in offline, and are there all managed APs disconnect, or just a specific one? Can wireless station access to AP and Internet when AP's offline?
also, It will be nice if you attach the diagnostic information of both NXC and issuing AP, which helps Zyxel official user analyze the symptom and find the root cause.
Also, it will be nice if you can provide the network topology of how AP/NXC/Gateway connect to each other. And trying if you can ping to the AP by NXC when it is offline. Which helps to clarify the network topology and the traffic status between them.
Good morning,
my zyxel network consists of 1 x USG110 (4.35 AAPH 2) and 3 x WAC6103D-I.
All APs are in managed mode. There are always two APs online.
In "Query Controller Log" there is a message visiable:
alert
CAPWAP
AP Disconnect. MAC:BC:99:11:D5:64:C0,Name:AP-Wohnzimmer,Reason:Idle in RUN State,Model:WAC6103D-I
What is the reason for these problems?
In addition:
Now another AP is offline. Two are online.
@drmi Did you buy any additional APC license for USG110?
By default USG110 is only allowed to manage 2 APs. You can buy additional license to expand the management quota (By contacting to your regional sales.)
You can search for your regional sales from the link below: https://www.zyxel.com/where_to_buy/where-to-buy.shtml
Thank you for your answer. Ok - I understand. Does a USG210 allow to manage two APs too?
Hi @drmi,
The default Managed AP number of USG210 is two.
Here is the specification for your reference.
I am currently experiencing the AP Disconnect, Idle in run state problem repeatedly on a new ATP200 with two managed WAC6503 AP's. Can be once or multiple times a day. The ATP is running 4.35(ABFW.2) and the AP's are running 5.40(AASF.2). I cannot see anything in the logs which causes the AP's to disconnect. The simply go off and then take up to an hour to reestablish with CAPWAP. I don't see frequency issues or other deployment problems on an analyzer.
Is there new firmware patch for this? Any additional info needed to help you diagnose?
@RichardHan
My problem was related with samsung mobile phone. When the Samsung user connect the AP. AP cant work properly because of missing igmp packets. Zyxel turkey captutr controller and They will release New firmware as soon.0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
