vpn local ip address
I configure a Client to site IPSec Vpn on my USG40.
usg lan is 192.168.1.xxx
How can I to see the local ip assigned to my remote pc conneted to usg by vpn?
when I connect by VPN on dashboard USG panel DHCP table show me 0.
thanks.
Damiano.
look in monitor
hi, thank you, my VPN is IPSec and not L2TP
in VPN Monitor IPSec I see this:
Hi @damianodec,
In CONFIGURATION > VPN > IPSec VPN > VPN Connection > Mode Config, if you enable Mode Config and assign IP pool for IPSec VPN clients, you can find the assigned IP for each PC in MONITOR > VPN MONITOR > IPSec > Policy.
hi @Zyxel_Emily
thank you, can you send me a link that show me complete configuration ? (ipv4 address configuration object, VPN gateway, connection...)
bye, Damiano.
Hi @damianodec,
Attached is the configuration guide for your reference.
hi @Zyxel_Emily , thank you, I'll try it.
bye Damiano.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
