USG60W - Firmware 4.35 - Patch2
If the formal release firmware works fine in your environment, we will suggest to keep using the formal release version.
Those fixes in WK firmware that are not included in the current formal release will be patched in future formal release as well.
5
Hi @ChristianG,
The firmware WK46 is just a hot fix. We merge most fixes to firmware WK46 for users to verify issues. The firmware is not officially verified by Zyxel verification team.
The official firmware 4.35 patch2 includes fixes of some major issues only. You can find the modification of 4.35 patch in the release note.
Hi @Zyxel_Emily
then I ask the question the other way round ? is it useful to switch from WK46 to patch 2 - or are there any bug fixes missing from WK46 that can bringup new side effects ? ?
Regards
Christian
In my case V4.35(AAAA.0)ITS-WK46 has a fix thats not in V4.35(AAAA.2)
5
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
