Limit VPN time connection
Good afternoon, is there any possibility to limit the time that the activated VPN connection remains on the client PC? I would like to limit the time in minutes in case any of the clients do not close it and leave it open.
For example, after 60 minutes of connection, disconnect the client PC and if you want to stay connected you have to perform the "dialing" again.
Thank you.
Hi @Ricardo_ITS
If you're using SSL VPN,you can set the settings by following these steps,
Go to Configuration > User group > create the SSL VPN user and Edit it.
Edit the user > set Reauthentication Time to 60 minutues
And if you’re using IPSec VPN, you can set the settings by following these steps,
Go to Configuration > IPSec VPN > VPN Connection > Edit IPSec VPN connection
And you can set the SA Life Time to 3600 seconds.
5
Hi @Ricardo_ITS
5 -
Thanks a lot, i´ll try it.
Good morning, I'm trying the solution but it doesn't work for me. I have it marked at 3600 seconds, but when it reaches the time limit, the VPN automatically reconnects and is not what I want. What I want is that if a client leaves the VPN open after 3600 seconds, he will throw away the connection and have to re-enable it manually. Is there any way to do this?
Thank you and best regards.
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 481 News and Release
