SBG3500's multiple Vlan
Zyxel_Charlie
This discussion was created from comments split from: SBG3500 PPOE Vlans(PPPoE on VDSL with multiple VLAN for triple play environment
Charlie
Charlie
It seems the ISP have VLAN 6 as untagged then 4 & 8 as tagged. Can he then not 'simply' create VLAN 4 & 8 and set let's say port lan 2 to VLAN 4 untagged & port lan 3 to VLAN 8 untagged?
Johan all services are in Vlans over PPPOE, and the internet service is on the ISP default routers set as untagged (trunked).
Then the unit(s) that connect to let's say port lan 2 (on VLAN 4) gets IP from the ISPs DHCP server on this VLAN. Which I believe would be the practice for most ISPs when providing IPTV, all IPTV boxes/units get their own IP directly from ISP rather than local IP from the gateway/router.
------PPPOE------\
=== Vlan4 voip ==> \ -------------------------------- ==> VLAN4=> Voip VLAN4 tagged
ISP=== Vlan6 Inet ==> |Router DHCP_client @ Vlan6| ==> VLAN6-> default/VLAN6 untagged
=== Vlan8 iptv ==> / -------------------------------- ==> VLAN8=> iptv VLAN8 tagged
- 212 Nebula Ideas
- 548 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 469 News and Release
