How do I lower down the WiFi power by CMI for USG20W-VPN?
Hi @YYY
Here is the command it allow user to lower down the output power,
Router> enable
Router# configure terminal
Router(config)# ap-group-profile default
Router(config-ap-group default)# slot1 output-power 30
Hi Jerry,
Thanks, USG20W-VPN TX's power spec as below. Several questions need your help as well.
Q1: it means a,b,g,n,ac @ 2.4G and 5G are lower down together on "slot1 output-power 30" ?
Q2: what will be min-TX power (dBm) for a,b,g,n,ac @ 2.4GHz and 5GHz
Q3: slot1 output-power 30 -->does this mean out power = 30dBm ?
if no, any rule or formal to indicate the "?" dBm vs slot output-power "X"
thanks
YYY
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
