USG20W-VPN Easy VPN beyond NAT not so Easy, unable to make L2TP avalaible
fleb
fleb Posts: 2 image  Freshman Member
edited April 2021 in Security
Hello
have USG20W-VPN and try to make L2TP connection from android.
I use Easy VPN Mode, router to configure.
I've a first IPSec configured, this use SSL and not L2TP
When I try to connect my android phone, the connexion seems negotiate between first IPSec configuration and never with second configuration...
How I can tell to use second L2TP Ipsec configuration when android phone L2TP connection coming?
Thank you for any help,
Regards
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @fleb
    If there are multiple IPSec VPN Connection settings, you can Go to Configuration > VPN > L2TP VPN to choose the preferred VPN connection rule in L2TP setting page.
    2020-01-07 18_30_59-2020-01-07 18_20_54-[zywall-usg-20] (10.214.48.49) - .__ Welcome to ZyWALL USG 2.png
    To build L2TP VPN connection on the android phone, you may refer to the guideline as below:
    image001.png image002.png image003.png image004.png image005.png image006.png image007.png image008.png image009.png image010.png image011.png image012.png image013.png
  • fleb
    OK thank you, this seems working at least to make connexion between Android an Zyxel.
    Regards
