USG 110 - SSL VPN - NO Extension network
Hi All,
i have a problem with USG 110 with firmware 4.35
I have setup a VPN connection and enable Extension network but i can't explore my local network (ping and tracert not works too). I have add my Lan in network list and when i connect with SecuExtender i can see my subnet (192.168.2.0/24) in Routes
I think there is a problem in Security Policy because if i disable it (uncheck Enable Policy Control) i can explore my local network and ping too
I try to delete and re-create SSL VPN policy but don't solve my problem
Thanks so much
Roberto
You could check the Zone setting of your SSL VPN policy.
Then, check if the security policy is allow the VPN Zone to your local network.
Hi Ian,
thanks for reply
I have these settings
Have you some idea?
Thanks very much!
Roberto
Hi Roberto,
we've got the following incomming firewall rule in place for our SSL VPN, where we have full access to our Company LAN:
Hi all,
for you information
I reboot the firewall with old- Firmware ver. V4.35(AAAA.0) and now it'works again...
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
