USG60W - display blocking internal a vLAN
ChrisGer
ChrisGer Posts: 206  Ally Member
Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
edited April 2021 in Security
Hi ZyXEL Community,
wish all a happy new eve and found another feature in the WK46. The WK46 him self is working fine, but i've no idea why internal a vLAN is shown a blocking inside the vLAN ? ?
i've enable the deafualt blocking rule at the end (default rule) and get tons of messages as shown in the LOG (communication inside a vLAN - without L2-Isolation).
The devices are also in the whitelist existing to avoid any issue.
Any idea what happened ?
Thanks forward and best regards
Chris
    PeterUK Posts: 3,892  Guru Member
    Do you know what the traffic is?
    Could it be that some traffic is by VLAN and other is not?
    Maybe you have proxy arp or need to have a firewall rule VLAN to VLAN.
    Can you check source/destination interface
  • ChrisGer
    Hi @PeterUK
    thanks for your quick response. the traffic is between wiereless sourround devices speakers/subwoofer in the same vLAN (51200 is for sync the wireless sourround components). ?
    I remember you had the same WK46 on your device ? ?
    Thanks forward
    Chris
