IPSec VPN to Azure
SecureShell
SecureShell Posts: 2 image  Freshman Member
edited April 2021 in Security
Hi, I am using USG20W-VPN device and using a dynamic public IP. I want to create a site to site VPN to Azure. I followed the procedures in the article described :
How to Configure Route-based IPsec VPN to Azure (VTI over IKEv2/IPSec)
But its not working. Can somebody help me.
Thanks in advance
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    edited January 2020
    Hello SecureShell,
    When you completed the setting, the issue you encounter was;
    1) VPN tunnel can build up successfully, but cannot ping to Azure virtual network host.
    or
    2) Just VPN tunnel build up fail?
    The way to trouble both case is different.?
  • SecureShell
    Hi Lalaland,
    Thanks for your response.
    I checked and found that the tunnel has been established, but I couldn't find any place at Zyxel console to find that information. I could only see this at Azure on Virtual Network Gateway (connected). I should have checked there first before making this post!
    Thanks anyway.
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @SecureShell
    You may use "show sa monitor" in the console to realize the tunnel connection status
