USG20W behind a Fritz!Box connecting to NordVPN VPN service
John_de_Jutter
Dear reader,
About setting up a USG20W behind a Fritz!Box router to connect to an external VPN service NordVPN. Since NordVPN’s servers stopped supporting L2TP/IPsec and PPTP connections since December 1st 2019.
Q1: Can this be done?
Q2: How can this be done? Any link to a tutorial or description would be nice.
Thanks for your effort!
If L2TP or PPTP are not available for it, you can use IPSec VPN to build it.
Here is the reference how to build IPSec VPN behind NAT
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=015405&lang=EN,
You can refer it to setup the settings.
With double NAT, you have to check the port forwarding and the rule on fritz-box.
- 441 Beta Program
- 293 Service & License
