USG1100 - How to receive an alert when WAN disconnects or reconnects?
imaohw
imaohw Posts: 124 image  Ally Member
First Comment First Answer Friend Collector Seventh Anniversary
edited April 2021 in Security
I would like to receive an email alert when one of the WAN ports changes from ACTIVE to DEAD or from DEAD to ACTIVE from a connectivity check.
I went into log category setting for email server and changed Connectivity Check (inside Network) from Normal to Alert. This works fine for when the connectivity check fails and the port is set to DEAD. I receive an email. However, I do not get an email when the connectivity check starts working again and the port is set to ACTIVE. I do get a log entry.
It would be helpful to receive an email when the connection comes back up.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @imaohw
    Now, we can only receive the email when the connective check fail, but there is no email when the session comes back.
    Thanks for your feedback and we will put this enhancement into idea section for future evaluation.
  • imaohw
    @Zyxel_Jerry - thanks for the follow up.
    The way it works now; I know there was a failure which is very helpful. Concerned, I then log in to check on the status only to mostly find that the issue has resolved itself and I didn't need to worry.
    An alert on restoration of the connection would reduce unnecessary panic.
