USG60W Limited AP for the internal AP
Hallo,
why do i get with WK51 the Icon on the AP-List that my internal AP is a "limited AP"?
I also noticed that on a USG110 and USG210 the download of AP Firmware 5.40 Patch 2 seems not to work. For a short time it is saying downloading Firmware but later it states in the log that the download failed and the check Firmware button is no longer working.
Hi @Wolfgang
New AP FW was uploaded, tried to reboot the device, and click recheck and apply then the issue will be gone.
I have rebooted the USG60W with WK51, rechecked and applied, but still have the same "Limited AP" Icon for the internal USG60W AP in the list of Access Points.
Is there something different to do?
I would like to analyze your configuration first, so please private message the configuration to me.
You can get more information by following these steps.
You can go to Monitor > AP Information > AP list > click more information
If it is limited AP, it will show up which feature is no longer supported.
You can refer to this article :
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=016576&lang=EN
Problem: 11ac-capable on Radio2
I have updated to the latest FW WK01 and now everything is working as expected.
Hallo,
i am now on WK13 and since some WK-Builds i still have the same Non-Supported: "11ac-capable on Radio2".
Why does this happen?
In the tech. specifications is Always written that 11ac is supported.
Thx
Wolfgang
@Wolfgang
From the spec, the USG60W internal AP only support 802.11 a/b/g/n, without ac.
Therefore, when you did as below
1. Select to be 11AC on802.11 Band
2.Press more information, it will show 11 ac-capable on radio2 (Non support)
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
