QoS Egress going over the limit.
I see thats too bad but still it will be looked at in 2020 so I'm happy for that at least.
Just wounding when this can be looked at again in 2020 to fix Egress going over the limit currently I have 5Mb upload speed but have to limit it to 1984Kbps to stop a download and upload at the same time from hitting my 5Mb and buffering ping goes high.
Hi @PeterUK
This improvement was added into the current firmware but not formal released yet.
You can use the command below to change the BWM counting method.
Router(config)# bwm control-tcp-ack
I’ll send it to you in private message.
Its great this is been looked at it really should be a check box option the USG60 that I used as the QoS has changed to a VPN300 so I hope to get the update soon for testing out.
Downloaded 4.35(ABFC.0)ITS-WK8-r92091 and found it has bwm control-tcp-ack for my VPN300 so this has now been solved.
My ISP now limits me to 10Mb I limit to 9.4Mb and now get a good ping when maxing out my connection for download and upload.
- 441 Beta Program
- 293 Service & License
- 461 News and Release
