Zyxel usg 20, for video vpn tunnel : WAN auto renew ip
rickard
rickard Posts: 1 image  Freshman Member
edited April 2021 in Security
I have problem with WAN auto renew ip if wan by dhcp from other cheap router.
When something happened with that cheap router our zyxel firewall lost internet until u press renew ip, ip g et the same but start working , if put static same problem.boot- client not help as well. Need some scheduling inside firewall which one will release and renew for example every 5 hours.
Frimware Version : 3.30(BDQ.4)/1.14
i believe its a bug in the frimware is there is any new firmware that i can install it on this firwall.
