CAPWAP version for 4.35-WK45
Hallo,
on download page of the Weekly version there is a message on top to manually set the capwap Version to 5.40(.1)-DF-2019-11-8 . Is this Version newer than the one found by the mechanism which is behind the check button?
Is there any Information what have been changed?
Is this Firmware only for external AP or also for the integrated AP (USG40W, USG60W)?
Thx
Wolfgang
Best Answers
Hi @Wolfgang,
The AP firmware 5.40(.1)-DF-2019-11-8 is for external AP only.
It is newer than 5.40 Patch 1 and it fixes the issue "managed AP default admin credentials do not change".
5 -
Thx for the answer.
PS: By error i have clicked "not answered", but can not modify it now. But really it answers my Question.
Thx.
Hi @Wolfgang,
The AP firmware 5.40(.1)-DF-2019-11-8 is newer than 5.40 Patch 1.
5
Hi @Wolfgang,
5 -
Thx for the answer.
Thx.
Hallo,
i expect in WK46 this newer CAPWAP Version is already included, correct?
Hi @Wolfgang,
The AP firmware version is still V5.40 Patch 1 in the firmware 4.35 WK46.
The fix in AP firmware 5.40(.1)-DF-2019-11-8 will be included in USG's next official firmware 4.35 Patch 2 which will be released in the late December.
Thx.
I have done a "check" for AP-Firmware with WK46 and found a V5.40 Patch 1. Is this newer than the "DF-2019-11-8" Version?
When i do a "check" on the WK45 where i have manually installed the AP Firmware, i do not get a newer one, also it Looks like it not really checking but more ignoring that i have pressed "check" .
Hi @Wolfgang,
5 -
Hallo,
i have seen there is a new AP Management Firmware 5.40(.2)-DF-2020-01-10 on the support.zyxel.eu Website under Weekly firmware.
Can you pls. give as a little bit more informations so we know what is fixed/updated and for what Firmware versions it is valid and/or should/must be installed. Also if this is only for Weekly fimware or should also be applied to a offical Firmware.
Thx
Wolfgang
I also got this AP firmware 5.40(.2)-DF-2020-01-10 from zyxel support last week.
It fixed the AP reboot issue caused by LLDP protocol.
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 76 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 890 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 203 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
