Is it possible to have same LAN subnet across VPN?
We have some security hardware which consists of a server that will sit in our HQ office and remote units that will sit in branch offices. The server and remote units MUST be on the same subnet. e.g. server is on 192.168.1.1 branch site 1 remote device is 192.168.1.2 branch site 2 remote device is 192.168.1.3
Is it possible to use this scenario and which VPN type must we use?
There will be a single VLAN in use as the firewalls and switches will be dedicated to doing security access and nothing else. I'm just not sure how routing would work. Thanks in advance
You can follow the guide to set the outbound SNAT and inbound DNAT in VPN connection.
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=016094&lang=EN
5
5 -
This link is not working
can someone help me?
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
