Which license to buy for connection SSL VPN (secuextender software) zyxel USG 100 plus ?
Hello to all,
i have a Zyxel USG100 plus firewall with 2 free ssl vpn connections. (I connect with the windows software application "zywall secuextender")
I would need to increase the ssl vpn connections.
Which license should I buy?
Is this ZyXEL LIC-SSL-ZZ0015F ok?
Does the license last 1 year or for life?
Thank you!
Hi @kernel24
The USG100 plus is EOLed and the license of this model may not be purchasable now.
Or will you consider the USG110 which can fulfill your requirement?
Here it is the data sheet for your reference. If you need further assist on the purchasing, you can share your region to me in private message and I'll redirect you to our regional sales who can help on it.
ftp://ftp.zyxel.com/USG110/datasheet/USG110_14.pdf
I don't understand if the SSL VPN licenses for the zyxel usg 100 plus are no longer valid, or are they no longer on the market?
if I search on google "LIC-SSL-ZZ0015F" I find many sellers who sell licenses.
My question is this ...
... if I buy this license, will it not work on my usg 100 plus?
At the moment I don't want to change firewalls.
Thank you!
Goodmorning everyone,
at this point I have to change the firewall.
The USG 110 is very expensive.
I am evaluating the Zyxel - ZyWALL VPN100.
How is the VPN100 different from the USG 110?
Is the VPN100 configured the same way as USG models?
Thank you all
Hello @kernel24,
I would like to invite you to compare the mentioned gateways using the datasheets:
ftp://ftp.zyxel.eu/VPN100/datasheet/VPN100_3.pdf
ftp://ftp.zyxel.eu/USG110/datasheet/USG110_14.pdf
The VPN100 seems to have a slightly higher firewall throughput. But please have a look which features are the most interesting for you.
Best regards
Lukas
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
